33 LED bulb availability
Thank you Pete! I got $50 off by opening an Amazon CC. I have no bills, use one CC and pay bill in full monthly so no fees. I also get cash back on the one card I use. All I need now are LED’s for my 1158 tailamp and 1129 park lamp.
I'd like to change my 34 out too. I have stock lenses with sealed beams under, got caught in the dark coming home last week, very dangerous experience. Didn't realize I was supposed to remove the old lenses. None the less I think leds would work better. Do you use the stock lens over leds?
Thanks Terry
Ken, can you tell us exactly which tail light bulb you ordered? There are so many listed to replace the 1154 I need (6 volt, offset pins, positive ground compatible). Some are conventional bulb shape, some tower shaped, different placement of the LED's, etc, etc.
Your photo is impressive. You got one that appears to work great in the 1940 housing. I want to order exactly that one..
These are the ones I used for my taillights. 6 volt offset pins. I used these small bulbs in the dash and parking lights. Got them from Amazon
Jay, Here’s the link.
https://www.amazon.com/Ruiandsion-B...-Negative/dp/B079HSFXP4/?tag=atomicindus08-20
