33 Ford four door
Could you send pics of the extra stuff - the door and pics of the floor and dash. Also the roof . Where is the rust ? Is What is the number stamped into the frame by the steering sector ? The last 34 I bought in canada was a C18P serialed car - canadian built . Thanks David J
The car has a small amount of rust out in the front right floor, pass rear fender well, and where the cowl fastens to the floor their is rust between the layers of metal. The worst rust out is the windshield header panel. The frame horns are also missing 3 or 4 inches off the ends. In the extra parts both headlights have a small hole drilled near the bottom for ground screw, and need some dinging out. Both fender brackets were broken but never welded. ( I tacked together) The car is a Canadian car with serial # C18H 4275.
Thanks for the reply and here are some more questions : Can you get pics of the windshield , window mouldings , better rear fenders and running boards and the bottoms of the doors - inside and out and the rockers . What will there be for paperwork ? The last one I bought came with enough to get a title here . That one came from Alberta and they don't title things like this . Do you have the poor fenders still ? They are still bits and pieces . What is the bottom line on this ? I used to work in Portal ND so I know the area and stuff isn't very rusty up there !!!!! Thanks David J
Yes, still for sale. My internet is not working well. Will try to send more pics tomorow. Fred
Ph. 306-586-1275
Hi.. From B.C.... I was wondering if you have any Inside Door pull handles from the car ? as I'm looking for 3 of the Nickel plated ones, they attach to the door inside just about 6 inches from the front edge ; if you have any, doesnt matter the cond... and what would you ask ? thanks so much , Dale in B.C.:confused:
