33 Ford Clutch will not work???
I have a 33 Ford Roadster with a 59AB engine and 38 or so transmission. I took it on a tour in April and when I returned I put it on the lift in my shop. I went out and started it today (for the first time since April 8) and when I tried to put it in to gear it wouldn't go in to any gear it just ground the gears. The pedal is connected, but the clutch doesn't seem to engage. What can I do. I sure do not want to pull the engine or rear end out to get at the clutch. What do you think has happened.:confused:
Sounds like the clutch plate has stuck to the flywheel/pressure plate. [from sitting] Get it running, jam it into gear it'll break free. Alternatively, tow it in gear, and once at speed turn the ignition on so the engine fires up. It'll break free. Brian
One possibility is that the clutch disc has become stuck to the flywheel. With engine OFF and on level ground (nothing in front of or behind the car), prop the clutch pedal down all the way. Leave the trans in 1st gear and try pushing the car front-to-rear to break the clutch disc free. It will help to get some helpers to do the pushing. If this is the actual problem, it should resist at first and then break free and the car roll easily.
"[from sitting] Get it running, jam it into gear it'll break free."
You are kidding, of course.
Orca, don't even think about doing this.
Listen to Mac. If his advice does not work, come back.
No, I am not kidding, I recently experienced this exact same dilemma with my Ford 8N tractor, tried rocking one of them? It was well stuck, didn't free up until I got it into top gear. But it freed up. Guess I must be one of the 50% under the average, lol Brian
Brian, we all have our days below average.:)
My concern is that your method is far more brutal than necessary. It also does not recommend whether the clutch should be depressed or not ... or which gear to try it in. If Orca is having this problem for the first time, he may really damage his transmission. I see teeth chipping regardle$$.
If the car has not run since April, his "stuckness" may be very slight ... Mac's advice is safe and effective.
Before jamming it into gear with the engine running and after trying several other safer techniques, I'd soak it for a week with lots of WD 40 ... which works well from my experience with no harm to the clutch.
I would start the engine, warm it up... Shut it off, put it in gear-and start it in gear with the clutch pedal depressed... Accelerate, decellerate-not violently... I like Mac's idea, but I'm lazy... Karl
"How do I soak the clutch with WD40?"
Orca, no need to do that yet.
First, try Mac's technique. If that doesn't work, try Karl's ... which is one I had to use routinely on one car I owned and now usually try first. If you start it in gear with the clutch depressed, keep the clutch depressed, but be sure you're comfortable driving that way. You can easily pull it out of gear into neutral while running if you have to ... just make sure you have plenty of clear street ahead of you.
Other guys like to jack up the rear, start it in gear, clutch depressed, and jam the brakes on.
I discovered the WD40 method after wearing myself out on a '37 PU. I tried every method and had resigned myself to pulling the transmission. I soaked the clutch down through the inspection opening and went home. A week or so later came back to find the clutch loose as though it had never stuck.
I have also had numerous "frozen clutches" on engines that had sat a looong time and that involved extreme rust and corrosion. (For guys who have done it, how about a French Vedette "V8-60" with an aluminum transmission case and bell housing, everything rusted solid including the pilot bearing and engine itself ... almost no access to the diaphragm bolts.)
Your situation does not sound very serious since the car was driven recently.
( ... "French Vedette "V8-60" ... See, Brian, THAT was a below average day.)
Pull the car off in high then hold the clutch in while gassing it and letting off until it pops loose. When it does, slip it a little in high to burn off where it stuck. High has the least possibility of damaging the trans. DO NOT JAM IT IN GEAR WHILE RUNNING, dire consequences will result.
Next time you want to let it sit for 6 months,prop the clutch pedal at least part way down,,,better yet DRIVE IT, thats what they are for!
