Chris Marshall
I was trying to lube the driver's door latch on my 33 coupe yesterday and the latch locked up. Both handles locked solid. Finally gave in and took the door apart to get the latch assembly out. The toggle from the inside handle that's under the door latch anvil (for lack of a better term) was jammed out of place. No way to get it back to normal without knocking out the rivet that holds the anvil and toggle in place.
After all that here's my question - does anyone have a source for this special, shouldered rivet that holds the anvil and toggle in place? This same rivet also holds one of the two upholstery door panel clips in place on the interior side of the latch mechanism.
Rivet shown in photos below.
