John Gibson
The striker plate on the drivers side door of my 33 Cabriolet is very loose. I’ve tried to tighten it up but it appears that I probably have either a stripped bolts, stripped cage nuts or both. It wiggles up and down as you can see from the two photos. I have circled the plate in a red line. I have two questions, first what is the size of the two bolts the attach the striker plate to the door frame and second, how much of a job is it to replace the nut that is in the cage that is attached to the body.
Thanks, John
Thanks, John
