'33 back on the road, time to move on
After limping my '33 home from a drive some time ago and some diagnostics, I pulled off the distributor, filed and adjusted the points and it was back on the road running wonderfully.
Now I am free to put new transmission bands on the '15 and pull the rear axle to check ring and pinon backlash
Get a modern pinion bearing set up for that T while you have it down, much more dependable than the original.
