33 B Model motor info
Bruce in southern OH
Have a 33 B motor in a 33 BB, cleaning up and the lower steel pipe between engine and lower radiator outlet is rusted with pin holes, looked in Synder's and Mac's, nothing found, do you all know of a supplier, this has the drain in pipe, thanks again Bruce
Charlie, thanks called his number at 1:00 PM Eastern Standard Time, very nice whom every I talked to, he said they have an out side vendor reproduce the Model A lower pipe exactly like the orginal with correct bending machine and flare, told him this was just like the A model but longer, not interested in asking vendor to make a special piece, also told me maybe cut two model A's up and make one, will look into this, would like to find the correct flare tool and I would make one and for whom ever else needs one, thanks for your help, any more suggestions please email, Bruce
Bruce,
How about a muffler shop with a tube bender? Then you would still need the pet ****. Will the "A" part work with a longer hose?
Charlie Stephens
No, I compared the two today, angle is a little different, also the A model pet **** is in wrong location, I think I will try a muffler shop just to see what they can do, would like to have the round smooth flare on each end, any one got an idea or the correct flange tool?? I will use a long flex hose temporarily and see if I can locate one, forever4 of Ford Garage says he has one but it is expensive, he is out of town until Friday.
Do you have information of how tail pipe was supported, everything good except the tail pipe is held up with wire!!! thanks Bruce
Bruce, I had a 32 B and I may have one of those which you can have for S&H but I need to know the dimensions to check it out. kc
