33-34 Rolling Street Rod Chassis
Ford1933
Taylors
SC
Price
In Ad
Last Call - INCREDIBLE BARGAIN - YOU WON'T GET A BETTER PRICE ON A ROLLING 33-34 CHASSIS THAN THIS. IT IS WORTH MANY HUNDREDS OF DOLLARS MORE THAN THIS PRICE - MAYBE EVEN A COUPLE OF THOUSAND MORE - IF YOU NEED AN ECONO CHASSIS THIS IS THE BUY OF THE DECADE ! ! ! ! I must sell by Wednesday night at midnight or I will not be able to buy the traditional setup chassis I want to replace this one with.
Here is a real bargain chassis for an economy Street Rod or rat rod project I pulled the body off and put it on an original unmodified stock frame. This chassis is fully boxed with Mustang II front and 8" Maverick rear on Chassis Engineering parallel leaf springs. It has a power rack but I do not know the condition of it. It comes with a decent original gas tank.
There are no calipers on the front which has 4 1/2" X 5 lug rotors (new but they have sat outside in the weather for about a year). I have a pair of uncut front springs and new stock type upper A arms. Neither of which has been installed.
The rear end has no brake drums or brake hardware but axles and lug bolts are fine and it turns over smoothly. Do not know what the ratio is. The wheels are old Boyd Coddington mass production aluminum wheels with dual bolt pattern. Tires have a fair amount of tread life left to them but they are nothing fancy. It also comes with rear spreader bar and stock rear cross member which is bolted in. It had a tube rear crossmember when I got it which I removed.
This chassis was setup with a 75000 mile SB / Turbo 350 which is available at extra cost. I removed the engine mounts because they were home made and looked like it - lol.
I can bring this chassis to the Shades of the Past Run in Pigeon Forge next week end if paid for prior to me pulling out of the drive way. I will assist with shipping but buyer has to make all arrangements and pay all shipping cost. I am located approximately half way between Atlanta GA and Charlotte NC a few miles off of I-85 ZIP 29687
$2700 takes it home if sold by Wednesday ! ! ! - which is well less than half the price of a repro chassis plus you get wheels / tires / gas tank.
Thanks
Mick 864.363.2905
