'33/34 rear fender question
JRShaw
Gentlemen: Are '33/34 rear fenders from a four-door the same as for two-door sedans and phaetons? Thank You in Advance for your help on this!!
The four door fenders will fit a two door. I do believe they will also fit the phaeton.
Yes they are. Also 1933 Victoria (1934 Victoria had a slightly different shape at the very back). Note that a coupe/roadster/cabriolet fender can be cut to be made into a sedan fender, the only differences are the width on the inside and the bolt hole pattern.
