Trelpdx
Guys,
I'm putting back together the front end on my 33 pickup and need to know the exact elevation of the radiator feet supports in relationship to the bottom of the frame so that I can weld in new supports. I have the front to back figured out using the hood and grille shell. If someone that has a 33 or 34 pickup could take a look that would be great.
Also, the hood doesn't seem to want to fold up more than about 45 degrees from horizontal. Should the hood fold up past 90 degrees and lay over onto the opposite side? If so mine is bound up pretty bad.
Thanks much,
Peder
Thanks much,
Peder
