33-34 light duty panel
55 dude
i have found some pieces to what i think are 33-34 panel. i would like to talk to someone who has one. thanks :)
Could be. The wheel well location could help to identify. If it is more off center to wards the front, then probably 32. Closer to center then 33-34. The door is for something more late 40's and probably not Ford.
As mentioned the wheel well location is different, '32 is 106" WB and '33-'34 are 112", but I believe the '32 looks more centered. The upper side panel reveal lines are different between the two also, with a radius that matches the one shown in your photo at the front and rear on the '32. If there is a like radius at both ends on the upper reveal line then it's '32, and if the rear is radiused and the front square you have '33-'34 quarters. The door shown is not Ford.
new pictures say it's 33/34! need id on fender.
Post a pic of the front lower section of the fender where it sits on the frame.There should be a small raised area near where the grill shell sits.If so its a 33-34 commercial.The dash is 33-34 commercial.
Most likely yes.A mounting hole for the front frame horn is in the slope next to where it flattens out .Maybe someone can chime in and post a pic.
