33/34 Ford door glass runs...need HELP!
no6
My coupe doors are 33 outside and someone incorporated 34 inners on the inside. I ordered a set of door glass runs for a 33. My coupe is chopped 4 3/4" so the runs are long. How do they attach at the top and does the foam rubber actually get glued to the top of the door frame? Any pictures of the mounting points or inner receivers for the runs front and back would be greatly appreciated.
You will probably get a better response if you post some pics of what has been done to your doors . The window stuff is COMPLETELY DIFFERENT 33-34 . Except cabriolets of course .
