Hi Steve,
Just read your post, and I had the same problem with finding a battery for my 1939 Ford Deluxe, but this is what I did.
I bought an optima V6 red top on Amazon ( https://www.amazon.com/Optima-Batte...g-Battery/dp/B00099HVN6/?tag=atomicindus08-20)
and then bought a case from Quail Services ( http://quailservices.com/index.html ) the vintage case is 2LD-II. I did buy a ford script at a car show and added it to the case. Quail Services was great to work with though and are very helpful. I had to make a cut diagonally in the bottom of the case so that the optima would fit and it worked perfectly. I will add a few photo's of the final product. Good luck and hope this helps!!
Jim
Jim
I have a 34 Ford script battery with an Optima battery inside the case which is deader than a door nail and Optima doesn't make that size battery anymore. Does anyone know of a manufacturer that makes a battery that fits the original battery carrier? If not I may have to modify the battery carrier to fit a lead acid battery. I cant find anyone that builds a battery that's the right size let alone Ford Script battery case any suggestions? Thanks
