sonny
Hey guys, I got my truck running today after a total rebuild. New pistons, rods, valves everything. The truck is spitting at idle out of the exhaust. I feel that the engine timing is a little too much advanced, by the way that it cranks over. I used Macs "nu-rex" tool to set the timing, by the way it's a slick, quick little tool. It gets you real close, real quick. The carb is rebuilt and seems fine. New plugs, points etc. I only put 10 miles on it today plus alot of idle time. Should I give it more time? Anything else I should be checking? The engine sounds great and for a 4cyl. has good power. Thanks in advance.
