'32 woody blueprints
Capn John
How do you go about obtaining '32 WOODY BLUE PRINTS??
Would the Ford Museum in Dearborn have them and if so the method to obtain them
Thanks,
JOHN
Contact the Benson Ford Research Center at the Henry Ford in Dearborn. You can Google their contact information.
Which parts are you seeking prints for? I ask I had obtained some of those prints many years ago (they're no longer legible) and they have many of them, but not all of them. You will need the part numbers of the components for which you are seeking prints. That challenge is often mitigated by summary prints for assemblies such as a door that list all of the part numbers of the components that make up that door.
Thanks DAVE, I'm looking for the tool box and top behind the rear seat and the metal area over the rear axle assembly where the wood attaches both in front and to the rear of it and the rear wheel splash panels joining this area on either side.
Capn John,
I have mine apart and can get you dimensions. I will not be able to get to it until the end of April. If you can wait and you can use the info. I can make up a quick layout for you of the wheel wells and floor pan.
Part pictured below.
Keep V-8ing and 4-banging!
Thanks, that would be great!
The real panel I have had the splash panels and blind nut receivers removed and I have to reinstall the. So I need the proper measurements to do the job correctly
Regards,
JOHN
The part number of the lid is B-150150 and that of tool box is B-150182. You'll be in good hands with Jerseyboy for dimensions for the steel floor section as his appears to be in good shape except for some minor rust damage on the edges of the wheelhouses.
Capn John,
Here are the measurements you are looking for. My apologies for the delay.
Let me know if I am missing anything.
