32 wishbones how to tell the difference
carcrazyjohn
I have 32 ford wishbones according to the bible .Now what are the measurements....Did the reuse the casted part with the ball in 34 .And hello Ryan ......
I think weld to weld is 45 on a 32 and 43 on a 33-34. If no one verifies, I will check tomorrow. I believe the ball forging is the same 32-34. Some of the A forgings were quite simular except bowed. I have considered flatening an A to fix a 32.
If you're doing a "stretch," say lengthening an A to use in a '32, or a "shrink," say '32 to '33 / '34, you'll have to heat and bend the center forging to get the perch to perch spacing right with the new leg length. For this reason, I think that the '32 center forging might be a different forging from the '33 / '34. Either that or they might have tweaked them at the factory. (Anyway, I have a nice '33 / '34 wishbone that I'd like to swap for a '32 if anyone is in the opposite boat.)
A while back, I did some measuring with a tape measure. (My numbers might be off a bit.)
For a '32, I measured 44" from centerline of ball to centerline of axle (measured along centerline of car.)
For a '33/'34, I measured 41-3/8"
Another time, I measured centerline of ball to centerline of perch pin hole at 47-3/4" for a '32 and 45-1/2" for a '33/'34.
Both cases, centerline of perch pin hole to centerline of perch pin hole was 37"-37-1/4", but it's easy to tweak that during assembly.
Hope this helps.
