wallymelton
what differences are there between the 32 ford b cab and the ford 33-34 1/2 ton truck cab? size, moldings, mounts, etc.? thanks
Is the cab width the same?
Hi; 32 cabs have some odd points: early 32's have reveal indents where the door edge closes, The tops are welded on the A pillars and the seam leaded, The tops DO NOT have a reinforcing ridge near the visor, some visors DO NOT have a center reinforcing brace, Cowl vents are early/late angles, ALL 32's have under seat gas tanks/ Split seat bottoms. Door hinges DO NOT have reveals around the hinge openings. These are just what I can remember. Join Early ford V8er's Newc
