32 Tall water pump pulleys
Gary-UK
So today I lost a chunk of one of my pulleys. What are my options? Are new ones available anywhere ?The pumps were done by skip whilst I was on vacation about 5 years ago and work great so I am just looking to replace the pulley.
If new are not available and I can find a later 33-36 pump are the pulleys the same?
Tia
Tia
:D Post a pic of the one you want to match . This will help find you one and also the 32 people will let you know if you have the right one . :D David J
Gary,
Yes, '32-'36 water pump pulleys are the same (except early '32 pulleys which were shorter from front to back) although some of the pulleys supplied for post-production service were pressed on rather than held in place on the shaft with a tapered pin. Obviously those without the holes for the tapered pin have a slightly smaller inside diameter for a press fit. There were minor differences in the pulleys in terms of casting marks (some have part numbers, some don't) and some NORS pulleys have more pronounced differences in the shape of the front part of the pulley.
Dave
I still have a pair that I can look at to see what the pullys are like. Can compare to the 33 thru 36s which \i also have.
The post should have said -compare with 33 thru 36ss which I also have if that is of any help
