Doodlrodz
- City
- Central
- State
- N.Y.
- Price
- in ad
Here's some '32 stuff that needs a new home. Complete early '32 rear end set up including axle ( without brakes ) radius rods, rear spring, rear cross member, and a torque tube, drive shaft will need to be lengthened as it was used with an overdrive unit. $400 Also have a '32 wide beam front end assy. including the spindles, spring perches, split bones, and a stock spring ( not in pics. ) also comes with the wishbone mounts. $650 '32 grille and insert that top has been filled in and sides trimmed. $550 '32 hood tops that need some repair with the center strip $175 Here's some pics.
