I just finished overhauling the steering box on my '32 Ford. When I Bench tested the box I went to install the pitman arm and noticed that it will only fit the shaft either at the 4 or 7 o'clock position. I assumed that if the steering shaft is at "high center" (half way between the 3 1/4 lock to lock travel) that the arm should fit at the 6 o'clock position. When I bought this steering column the pitman arm was missing so I never knew the arms true position. Am I missing something here?
Thank you in advance for the responses
