O Ole Lou Senior Member Jun 19, 2015 #1 How do you determine if a shock is working properly before installing. It is not locked up, it does have resistance and is not leaking.
BILL WZOREK Well-known member Jun 19, 2015 #2 Check the oil level & keep in mind the 32's are not that heavy of a car then when you x 4 shocks each shock does not need a lot of resistance to work well.
