32 rearend made from 34
true blue 32 man
Thanks to those that responded with dimensions to accomplish the cutting to make the changover. Now I discover the 34 reR IS MISSING THE DRIVESHAFT and the spline coupler pins and at the front end the speedo gear and snap ring. If anyone out there has a parts rear end with these parts would you pm me what you have and prices for same. Especially drive shaft and coupler. would 35 & up parts work? the minor stuff i think I can get from Macs Any help would be greatly apprediated. hoping to get my 32 driving for this summer. thanks Pete
34 driveshafts slide right onto the pinion - no coupler 1 pin . If you need to buy a driveshaft just buy a 32 . If all else fails I could take a driveshaft out of a 33-34 rear but I'd look for a 32 and save some scrrewing around . Good luck David J :confused: PS I have used 32 rears for parts and I have a drive shaft that is 51 5/8 " long . Dunno where the tourque tube got off to but the driveshaft is sitting here lookin at me . . I'll send ya a pm .
