You can get the gasket from thirdgenauto.com and perhaps they may have an original rear window frame as well.
Of all of the various questionable "better ideas" incorporated into Fords of thirties, few are ahead of the '32-'34 closed cab rear window inner frame attachment. With 22 screws, nuts, and lock washers involved and almost no room for your fingers to hold the washer and nut in place while you try and start the machine screw, it can consume hours and even days worth of effort. How it was done on an assembly line is beyond my imagination.
