what are the implications of not having the road draft tube on a aluminium 32 pan? Excessive oil changes? I expect it would probably cause more moisture, and maybe a few more contaminants, but that can be fixed by frequent oil changes I would imagine. There is still going to be a breather up top, so I cant see it causing a pressure build up????
Is there anything that can be done, besides installing a PVC? The only thing I like less than nasty fumes in the crankcase is ingesting them into the rest of the motor as well.
Thanks
Beech
Thanks
Beech
