32 kinkpins?
Marv 119
I have a new set of kingpins and dont know if they are for a 32 or a model A. Is there a way to tell? They are wards riverside part no 61-4213.
Realy dont want to buy more if these will fit.
Thanks Marv
To determine if your king pins are A or B style place the king pin on a flat surface, cup facing down, The shaft of the king pin will angle upward. From the end of the king pin shaft measure to the level surface. A - king pin measures about .700 while a B- king pin measure .950. The B king pin has a steeper angle but unless you have then to compare it is hard to determine. The 35/6 style, the king pin shaft is almost parallel to the surface.
