32 K member
jackson32
What is a good 32 K memder clutch and brake pedal 39 trans case with motor moubt and rear 32 to 36 adapter also have rear crossmember goiod condition
whats here is a very good 32 K MENBER 32 CLUTCH AND BRAKE PEDAL 39 ****** CASE 32 ****** MOUNT AND 32 TO 36 ADAPTER TO USE 32MOUNT WITH WOULD LIKE A VALUE
Is the k member complete with two legs?
What is the condition of the cross member?
Is the 32 pedal assembly complete with bracket, clutch and brake pedal?
The transmission mount should have a good vulcanized bushing with shim plate and four fasteners, washers and nuts.
All of the things are pretty pricy, the reproduction "k" member or cross member is about 500 dollars. Richard 562-338-4419
I am thinking these prices are a guess without seeing the items.
1932 Ford k member 500
1932 Ford pedals 200
1932 Ford transmission mount 50
1939 Ford transmission case 50
k MEMBER IS VERY GOOD CONDITION ****** MOUNT IS NEW AND I HAVE THE 32 TO 36 PIECE ID CALL IT AN ADAPTER TO MOUNT 39 CASE TO K MEMBER GOOD CLUTCH AND BRAKE PEDALI HAVE FRONT CROSSMEMBER REAR CROSSMEMBER V8 REAR NOT MODRL A REAR HAD ALL THIS BOLTED TO AMERICAN STAMPING RAILS GOOD 32 WISH BONES DRORED i BEAM AND MAYBE MORE
I am thinking no less than very good pieces are to be in my shop. I am still learning about automotive technology.
