Ghost, Look at the picture, second from the top appears to be a nos or nicely restored, at least one other looks real good, also one seems to be longer, maybe a BB truck? I was serious about the Old School style. My A has a cut off and welded up lite bar from an A where the end was mounted to the frame of the car and then the bar was bent into position, then it was cut off to do the other side, then when both sides were mounted to the frame the remaining bar was sized and welded to the mounts on each side. This is real old school but relatively easy. WHERE ARE YOU LOCATED? Maybe we can put a deal together. but one of my good ones will cost somewhat more! Regards, Tony call me if you are interested. 845-336-8839
