hb32
I am in the process of buying a 32 pickup but have concerns about the title.
Title does not have a usual "B" number on it nor does the frame in the usual 3 places.
There is a number stamped in the drivers rail beside the firewall which is not very readable and numbers stamped on top of and on the rear face of the rear crossmember. These numbers, without the "B" and stars, equate to a 34 VIN.
To add more confusion, the frame does not have the reveal on the side of the rails. I read the thread on the no reveal as well as the authors reply from the Ford archives.
Frame has all the tell tale signs of a 32 and is 106" wheel base with no signs of being shortened. 3 cross members look identical to 32 parts.
Cab and all associated sheet metal are 32.
Has a "B" motor with a coresponding s/n equating to a build of May 32 on the bell housing.
Title VIN has partial #`s of a s/n off the engine block starting with "SP" which I have had no luck deciphering.
Not sure where else to go with this and don`t want to get stuck with a lawn ornament.
