The spring is what you need to be thinking about. If you are running the 32 curved spring, you may find that there isn't room behind the axle - to achieve the angles you want and the locations you want (up top). In many cases, the dang shocks just don't fit well.
What I recently did for a 32 rear in a 32 was to use the lower wishbone mounts to make a custom bracket for the lower shock mounts (ahead of the axle). Then I made a 1.625" x .125 tube cross-member that mounts to the frame - just ahead of the banjo connection. This gives me my upper shock mounts - at the right angles, etc..
I'd never done this before, but it will be what I do on any 32 - 34 rear that is using a stock style cross-member and a 32 - 34 curved spring.
