Hi, I need to take the steering box out of my 32 roadster. If I remove the header & floor boards ,is there enough room to pull it out? It looks like we will have to remove the the engine. thanks jon flannery
It will come out. I disconnect the brake pedal rod and pull it back. Wrap cardboard around the mast jacket unless you are going to repaint it. Be carefull with any nearby wires. Starter cable is a problem. Disconnect the battery.
