32 ford steering box rebuild manual
rust revival
Does anyone have a manual or copy of how to rebuild (not adjust) (not modify )
Just stock rebuild the 3 tooth 32 ford steering box ,the hamb source everyone references to is kinds of useless without photos.
Thanks in advance
Other than obvious wear issues on the bearings and worm and sector gears, the Service Bulletin information is all that your need to restore your steering gear to its original state.
Ok I'll give it a try, but this being my first one I was looking for a detailed exploded diagram or similar, I have a box of 32 steering gears (all unassembled)
Figure 126 on the first page in the Service Bulletin (page 79) in post #2 above reveals pretty much all of the parts and there aren't that many.. Where it might get a bit complicated is if you have to replace the bearing race at the bottom of the worm gear as that requires a special tool.
