alchemy
- City
- Marshalltown
- State
- Iowa
- Price
- $400 firm
For sale is a very rusty '32 Ford pickup cab with both doors, door latches, and window mechanisms. The cab has a rather solid subframe, needing only a new back crossmember and a few cracks welded up. Pretty good compared to the rest of the cab.
Doors are kinda bent and have plate welded to the jambs over the bottom hinge. Probably need a full lower skin and patches on the upper edges as well. Inner bottoms need replaced as well.
Cowl would be savable with some smaller patches and reattaching the loose spots.
Back panel will need new bottom corners and lower patch. Some reconstruction of the lower jambs needed as well.
Top has a big dent and stress cracks in the jambs.
Overall, a good starting point for a guy who loves to sandblast and weld.
Price is $400 firm for the whole cab. No, there is no dash or firewall.
I would sell the pair of doors separate for $300. The latches are probably worth half of that.
I can send a bunch more pics via email, so PM me your address if you'd like them. Don't bother if you have an email firewall limiting the size though, as I won't try more than once to send a large file.
Thanks.
<<<<<<<<<<<<<<<<< SOLD >>>>>>>>>>>>>>>>>>>
Thanks.
