Harpkatt
Has anyone found a set of knobby tires for 32 Ford Wheels? I have a 30/31 Doodlebug that from the little history I have on the vehicle last had USED tires installed in 1969. They are ROCK solid. They are more like hard plastic than rubber at this point. It mostly used now for picking apples and running around the field. The car cannot get up the paved driveway in wet weather and it's not what you would call steep. Probably less than 18 degrees. I'm looking for some new rubber. Any suggestions? The current tires resemble these but with any inkling of tread in the middle worn away. Ignore the modern Rim
Weirder still even though all of the rims are 32' one tires somehow has a different diameter than the others. I think its got a 17" tire on there.
