Greetings
There are some small rubber rubbing blocks about an inch long that fit into slots on the door and window garnish molding. There are three slots on each door and one on each door garnish molding.
The ones on the doors seem to be straightforward in installing. The one on the garnish is tapered and I don't know which way to turn them slant up or down. My guess is to put the rubber block so that is has less chance in catching the glass or channel while being raised.
Does anyone have suggestions and any comment about the window channel kits available? I have acquired a Vintique kit but am concerned about the quality.
I will appreciate any input here.
Thank you
Jack
Thank you
Jack
