deuce-deacon
All --
thanks in advance for your help!
So I read several posts here on how the door check strap attaches to the car. But I'm missing something or having a hard time visualizing it.
Picture #1 is from the Bob Drake catalog. It appears the straight end of the t-shaped strap mounts to the B pillar with a cleat or bracket shown at the bottom of the same image.
The other end (t-shaped end) seems to attach to the door and slide inward when the door is closed. But something must hold it in place and let it slide. I have what is called a footman's loop, but the mounting holes on it are 2-1/4" center-to-center, while the mounting holes inside the door are considerably narrower. So the footman's loop doesn't look like the answer.
So my questions - am I missing a piece that mounts the strap to the door and lets the strap slide into the door? Or, is the T-shaped end of the strap fix-mounted to the door and then the strap just folds towards the inside of the car when closed?
any pictures or insights appreciated!
