32 Ford 3 Window Brookeville
Aledo
Illinois
Price
$39000
This is a Pure Hot Rods project that was assembled in house, with all seams butt and TIG welded, then metal finished. The substructure is plug welded rather than edge welded, trunk gutters are fabbed to be leak free and drain outside the car. The quarters have been cut and pushed up 3 inches, they are in the mock up stage ready to be fine tuned and finished. Special attentoin has been given to the overall fit and finish. The body comes with a flat firewall, grill shell, and all garnish moldings and window regulators. The wood is all installed except for the top, leaving options open. Doors and decklid are all hung and latched. The chassis is a new stamping that has been step boxed and TIG welded in a jig and has been kicked up in the rear 3 inches as well with a factory profile to allow the car to be extra low but still have plenty of ride without compromising the original feel. We have used a Chris Alston 4 link with the coil overs in front of the 9 inch rear, keeping it clean from the rear. Suspension is mocked up ready to weld up. The cross member is fabbed to give you an old school feel and look. The engine is a 521inch Ford that has been boiled and checked ready to be bored and assembled, the rotating assembly has all been balanced and is a stroker crank that will make a 30 over 460-521, the rods are H-beam mated to forged slugs. Heads are meticulously ported and CCed on a flow bench with stainless swirl valves. Trans is a Tremec TKO 600 mated to a Lakewood scatter shield. Will consider all trades but really wanting a 1956 ford panel truck of the same value. Call with any and all questions we are willing to separate drive train. Call (309) 582-3155 with questions.
Buyer will pay all shipping.
