It's easier if you disengage the regulator arms in a vertical position from the bottom of the horizontal steel channel that retains the bottom of the glass and prop up the glass and horizontal steel channel assembly with a piece of wood, remove the regulator, and lastly remove the glass assembly. That last step will be a challenge because of the 4" chop of the door window frame.
