O Ole Lou Senior Member Aug 3, 2015 #1 How do you disconnect the drive shaft from a 32 pinion gear, or is the drive shaft and pinion one unit? Does not have the coupler like my 38
deuce_roadster Well-known member Aug 3, 2015 #2 If your torque tube has a round flange, the pinion gear is on the end of the shaft with a nut just like a Model A. If your 32 torque tube has a scalloped flange, the driveshaft has a 10 spline coupler.
C Chisel Senior Member Aug 3, 2015 #4 Few pictures of 32 rearend rebuild Attachments IMG_1454_1.JPG 60.3 KB · Views: 19 IMG_1455_1.JPG 49.3 KB · Views: 21 IMG_1456.JPG 38.6 KB · Views: 21 IMG_1464_1.JPG 70.6 KB · Views: 19 IMG_1466.JPG 56.9 KB · Views: 21 IMG_1497_1.JPG 63.3 KB · Views: 21 IMG_1498_1.JPG 51.7 KB · Views: 22 IMG_1501_1.JPG 52.6 KB · Views: 19 IMG_1523.JPG 80.6 KB · Views: 25
