32 B oil Pan Parts
old28
camarillo
ca
Looking for the rear section of a 32 B oil pan that covers the bottom of the upper flywheel case.
Looking for a Model A oil pan that has been modified to cover the bottom of a B flywheel case.
Looking for a lightened Model A or B flywheel, must be usable.
I was able to find a lower B flywheel cover that was removed by the guy I purchased it form's grandfather. He did a real nice clean job and drilled out spot welds so the section is all there. I have it test bolted in place on my B trans case and will get pictures in the AM.
My question may be answered better when I have a picture in the thread to show the back of the case and the lower peace. Will the drilled section slide around the A oil pan or do I have to cut the drilled section off?
This is a real from the ground up build, starting with B trans with late model gears, Then lightened flywheel & 9" clutch. Then the motor build.
Here are a few pictures that may help with the question I have posted above.
