rbullockv8
I haven't been able to find a 30 amp or even a 20 amp gauge with the wiring posts for my 32 Ford (the one I have is a 20 amp with pass through loop). I'm running a 60 amp alternator, and it pegs the gauge momentarily when it initially spins up. Then it drops to about 12-15 amps.
So I was playing around just to see what I could do with a repo Model A ammeter. It's slightly smaller than the '32, and it slips completely through the dash hole. I needed a way to mount it in the dash.
I carefully removed the bezel from my 32 and found that the Model A gauge fit perfectly inside against the glass. I fashioned a bracket out of 1/8" ABS that wraps across the back of the gauge between the wiring posts--heated it with a heat gun and bent it around, drilled holes, and put screws through it to fit the back of the dash.
Came out pretty good. Although there is double glass, you can't tell by looking.
The only problem is the screw-on nuts on the wiring posts tend to come loose. I've tried single and double star washers, but no matter how tight I make the furled nuts, they come loose with a push of the wire connector. I'll have to try standard lock washers tomorrow.
Also, took the truck out for a tour of the neighborhood. New tires, torqued rear axle nuts, etc. Time to try it out. I'm posting a link, so we'll see if this works: https://flic.kr/p/QmmHp3.
