I ordered new stainless steel scuff plates for my 5 window. When the parts came in they were formed in blank to be cut to fit the application. The body has not been modified nor repaired with different or incorrect door sills.
The blank scuff plates are formed differently to the ones in my car. The ones in my car had 8 screw holes, 3 in the top and 5 along the lower part of the scuff plate. The new material is inadequate in width of the down turned flange, or the one below the door sill.
What I do not understand, I have talked to other vendors that have the same molding but no one seems to have the right shaped scuff plate material or weld flange extensions for screw holes to the incorrect material.
Guess I'll need to have the original zinc plated to appear correct.
Does anyone know where I could find correct replacement for original scuff plates.
