deuce-deacon
All --
Thanks in advance for your help.
I have a '32 3W coupe. I have made glass templates out of 1/4" masonite (luan), and have installed them in the car with the window channels, glass channel, rubber setting channel and window regulator. I made the glass template so its bottom edge is 1-1/2" below the window opening.
I have attached a picture showing my question. The glass sits in the metal and rubber channel with the rubber lip towards the outside of the car. When the glass is all the way up, the rubber lip is well below the body structure.
On original Ford cars, is the rubber lip supposed to push up against the body structure to create a seal? If not, did Henry install some other kind of weather strip to create a seal?
Thanks much for your help and insights!!
Richard
Richard
