32-34 brake drums and backing plates
sangar29
sunnyside
WA 98944
I have 7) 34 front hub/drums 2 Rear hub/drums, 2 rear backing plates, 1 front backing plate, 1 pair spindles and 3 spindles for the left side, 2) pair 32-34
rear axle housings, 1 torque tube, 1 drive shaft, 1 pair rear radious rods, 3) trans cases with gears pulled out, ! of the 32 cases has only the inspection hole, the size of a nickle, ( very rare ) 11 flat head heads with water pump openings at the front, and several 34 water pumps, 2) steering tubes with ign. lock and sw still mounted several exhaust manifolds, a doz or so 17 inch wire wheels, 1) 34 horn, 32-34 NOS rear spring, 3 pair front brake accuators, Have other 34 misc stuf. would like to sell all to one person, but will split it up. sangar29@centurylink.net
