birdball
- City
- Milford
- State
- Mi
- Price
- 300 obo
This is an original Ford 3.54 that has had the pinion modification to work with the scalloped flange 32-34 rears. The modified pinion includes the spacer that takes up the room between the double taper bearing and the pinion preload nuts. 6 spline. Will require motivation to your driveshaft.
Pictures can be found here:
https://www.jalopyjournal.com/forum/threads/32-34-banjo-3-54-r-p.1187871/
