32 3 window rear window
32Gnu
Is there supposed to be any supports holding the lower section of the wood/tray on the rear window?
I replaced the rear window wood, attached to the rear window strip along both sides.. everything appears to be tight, however I did remove the rear toll tray.. I am thinking I need to add some braces to connect to the rear trunk supports..
any thoughts?
