'32 3 window cowl vent repair
Deuce Coop
In case anyone needs to know, You can use Brookville Roadster's cowl panel for a Roadster, if you need to replace that same panel on a 3 Window Coupe. You will be trimming a lot of the new panel, but it works just fine. This will save you lots of $$$ between the roadster repair panel and the full top cowl replacement for a 3 window. Coop
