Patrick brophy
I thought I could just slide the bushing onto the stud and press it down with the valve cover. Not so.
The bushing was too loose and it just slide down the stud. I had to run a nut down and put a washer on top of that and than place the bushing on top.
I than had to run the nut up until the valve cover started to rock,and than back off until it stopped rocking.
I could see the bushing under the valve cover so I knew it was close.
Even then,the acorn nut just barely started on the stud.
Just one snag out of many.
