dmsfrr
KULTULZ, Old Redneck already knows it isn't the original '56 engine block. He got the car from his sister and brother-in-law, they owned it for 25 yrs.The only way to determine if a car has the correct engine (numbers matching car) is to use the BLOCK CASTING ID NOS along with the BLOCK CASTING DATE CODE and the ENGINE ASSEMBLY DATE (stamped) if found.
His initial question was... "How do you tell what year a 312 Ford Engine is?"
... I know it a 57 or later engine. Could be a 292 or what?
Here the number above the oil filter. 80150. 022AE. ...
All Y-block engine blocks have "6015" as their base casting number, with a letter/number prefix and usually a suffix letter, but they can sometimes be difficult to read.
I'm thinking the "80150" is actually 6015C and the "022AE' is... • C2AE ... like in the example photo below.
http://ford-y-block.com/Block%20identification.htm
a C2AE block is a Cleveland foundry 292 from a '62 full sized car (the last year Y-blocks were used in cars) or from a '62 to '64 truck. It would have originally come with a 2bbl carb. ....
