Alright have a problem with a 31 special delivery. The back right tire locked up at slow speed with no brake on. Did that in reverse as well. I was able to limp home. I drained the differential and use magnet and found nothing. The wheels will spin each other on jack stands under axle in gear but the gear in differential does not turn. I dread a rebuild cause it doesnt look cheap. I will try to investigate brakes as well.
