First let me apologize now incase this get long winded. To begin with this is my front passenger door on my 31 slant window sedan. In the normal operating position the door handle is in the 4:00 position. To open the door from inside the car I push down on the handle moving it from 4:00 to 5:00. I am also able to open the door from the outside using the scroll door handle. Now when in the car if I lift up on the door handle moving it from the 4:00 to 3:00 position the door is locked and I am not able to open it from outside. When I purchased the car the original door key was not included. I purchased a locking door handle from one of the known vendors and installed it today. The way that handle works is the lock tab engages in the escutcheon on the outside of the door preventing the door handle from turning. There is no connection between the outside and inside other than the square shaft that engages in the door latch. So if the inside handle is in the 4:00 position I can lock the car from the outside with the key. BUT if I lift up on the inside door handle moving it from 4:00 to 3:00 I am not able to open the car from the outside.
Basically I am locked out of the car!
What am I missing? Or is this normal operation? Do I need to disengage the 4:00 to 3:00 movement of the inside door handle? If so how is the accomplished.
Thank you for all replies.
